- Joined
- Jan 18, 2017
- Messages
- 87
- Points
- 27
Just a quick question our Fiat Panda has been stood for a few months, I usually start it up every couple of weeks and give it a full warm up, except this time I left it for maybe a couple months or 3!!
Now I can tell the battery is slightly lower voltage than normal as the central locking sounds a little less keen to open.
It turns over but clearly with no like normal engine turning over sound ie just spinning!
I'm guessing either low voltage or low oil pressure in the Twinair unit which relies on oil pressure to acctuate the intake valves.
Only tried to spin it over a couple of times, didn't want to draim the battery any further!
Do I persist in cranking it to get the oil pressure back up or try putting some charge in the battery or even attach a boost pack?
Is there a specific method to prime the oil into the Twinair unit?
Everything was fine prior to leaving it, so I doubt it is anything else and like I said I have been turning it over periodically, just not this last time!
