Technical Panda 4x4 Antarctica very low miles, some queries
Just to keep people up to speed. Resulting from our PM's, turns out this person is based in West Lothian, Not far off equidistant Edinburgh/Glasgow (arguably a little closer to Edinburgh) so not exactly "round the corner" from me and they would also have to endure a fair bit of "city mileage" to reach me - don't know if they are comfortable with city driving? They've decided to try approaching a local garage and I've offered to give additional advice if they would want that. (perhaps once they've had a quote?). I wouldn't necessarily be against actually physically examining the car - maybe popping a couple of wheels off and "investigating caliper/pad/disc condition (actually I would really enjoy doing that) but it would have to fit in with our extensive childminding/school pickup etc duties so might be difficult to arrange. I can't think there would be anything especially difficult in sorting this out so would expect a competent local workshop will have a satisfactory outcome.
Good luck with it Il Karro and do keep us all informed as to how it goes won't you?
Stay safe everyone
Jock
Here is an update people, decide today that i was taking the wheel off myself to have a look at the brakes. Already got a jack that I have used to change a flat before, but invested in a pair of axle stands too. There is a couple of reasons for the axle stands, so thought it was money well spent. I want to remove my alloys one by one and give them a good clean and i also want to clean and inspect the underside of the car.
Got the lug nuts loosened slightly then jacked up the car, could not get the axle stand in beside the jack there wasn't enough room, see pic 1 so where else can i put it .
Left the axle stand as high as it would go with about 5mm of clearance under the plastic cover which is over the sill, thought if the jack gave way then car would only drop onto axle stand, but didn't want to lower car onto axle stand because figured the plastic would break.
Removed the lug nuts and the wheel was stuck, used a mallet to thump wheel at alternate sides and it eventually came off. Took some pictures which i've posted and don't think the brakes look too bad, but wasn't prepared to linger with car only on jack.
So i cleaned the wheel surface and hub surface with scotchbrite then used a damp cloth with a drop of alcohol on it to wipe surface, then put a small amount of oil on a cloth and wiped surfaces with that, to stop it from sticking maybe i did the wrong thing but these were the only things I had at hand. Fitted wheel on, tightened lug nuts, removed axle stand, then lowered jack and tightened nuts.
Took the car round the block to make sure wheel didn't fall off, any tips or ideas or tools you think i should have please comment.
Tell me what you think of the brakes from the pictures. If i get the axle stands sorted out going to remove the wheels at home to loosen all of them.
So if nothing else today, this post might make you chuckle.:eek:
As believe you got car from a car supermarket. I would suspect their claims they do a proper inspection a lie if you struggled to get wheel off. Mine been off several times in the year owned (front discs and pads pre delivery, wheel balancing, brake cleaning, 4 tyres and front suspension arms). If your tyres low tread and front pads had it you'll know when you try braking hard from 30mph. Normally car literally stops on it's nose. Otherwise it'll lock up. Know this as I've done it. :eek:
No it was a private buy, the last service was done 09/03/17 with 1491 miles.
I know it is due a service, from then until now it has only done another 2110 miles.
I remember now seeing the ad. :bang: Major service and brake fluid change then good idea. And have plugs checked. 2 years or 18k over the top for changing those. But 5 years would be about right. The non Turbo Twin Air that never came here had different plugs with 4 year change interval. Once done it should be faultless. Also have coolant and waterpump done. Maybe check tyres for signs of rubber degrading too. :)
I hope you won't think me patronising when I say jolly well done! Especially with getting the stuck wheels off. This is very common on cars where alloy wheels have not been removed for some time. The alloy of the wheel and steel of the hub, assisted greatly by a liberal dusting of winter road salt react together electrolytically and corrode together. A good clean up with some abrasive paper or a nice stiff wire brush and a coating of anti-seize (more on that in a minute) will see this problem largely cured. I think I understand that you are working just on your jack at present? I worry that, especially if you are laying about things with a large mallet, the car might slip off the jack (but you seem aware of this possibility).
Jacking up and positioning of axle stands? I am obsessed with trying not to break the surface of the paint with my jack so I made up some "soft" faces for it. Here's some pictures and also of it in use:
Although I've never used one, I'm told a hockey puck (which is a hard rubber I believe) placed on the saddle (the black bit which lifts the car) is quite a good protector?
Placing the axle stands? They need to be on a load bearing structural part of the car. So on the sill where the reinforced jacking point is (but you've probably got a jack there already?) so a box section or subframe would be my next choice. I would tend to resist jacking in the middle of a flex beam type rear axle (like our ordinary 2 wd Pandas have) just in case it bent! Here's how I had the stands when I was sorting out the front brakes on "Becky" - our 2010 Panda Dynamic Eco. You'll notice the wooden block on the axle stand? it's there to both protect the paint and give a wee bit of "bite" to stop the stand from slipping:
Be very careful where you choose as you can do serious damage if you don't choose somewhere robust.
Looking at your pictures, particularly the top right and last ones, The discs themselves look to be in quite good condition. If the inner face of the disks looks like these outside faces I would say they are fine. I do notice, especially on the front one (top right image) that there is a rusty ridge around the outside and near the hub. A rusty ridge, especially round the outer edge, will often cause rubbing/grindy noises. You will find it quite easy to remove it if you rest a screwdriver on the Caliper (the matal part that holds the pads) and whilst pressing the blade of the screwdriver against the corrosion ridge rotate the hub so that the tip of the screwdriver "chisels" the rust off. You can to the same on the inner diameter although it's often the outer edge which causes most noise. When we bought Becky she had been lying for quite a while without being driven and her front discs had rusted up quite a bit. I had hoped that just driving her around and using the brakes aggressively would "bust" the rust off but after a week there was still a lot of "grindy" noises so I dismantled the front discs and they looked like this: (This was the N/S one)
Not at all good. I thought I would need to buy new discs. As there was nothing to loose I "attacked" them with a sanding disc and was amazed when the rust flaked away and left an almost perfect disc surface:
Notice that the whole friction surface is smooth. There is no outer or inner rust "band" to grind against the pads.
The last thing which is immediately obvious is that, again looking particularly at the top right and last pictures in your post, there is no sign of any ant-seize/anti-squeal compound anywhere. It all looks very "dry". I'm not surprised to see this. There is no time built into a typical service schedule to strip calipers off and clean and lube pads and calipers so it's typically not done (especially when brake pad condition can easily be seen without even removing most designs of alloy wheels!) My 3 year old Ibiza looks exactly like this and when I had reason to remove a wheel the other day I had to kick it quite brutally to get it off. Needless to say there was no anti-seize on either the hub or inside of the wheel! I doubt if the wheels have ever been off at any of the 3 services done by the main dealer whilst she was under warranty! Out of warranty now though so she's all mine and there will be a lot of little jobs like this for me to catch up with over the summer.
Now, regarding anti-seize/anti-squeal. Here's my little haul:
Back left is Ceramic grease. You can use it on brakes and general fixings like nuts and bolts which you don't want to seize up/corrode. But it really comes into it's own for preventing exhaust fittings from seizing up so making it easier to strip them down later.
In the middle is an "old favourite" of all mechanics - Copper high melting point grease. (Often called, generically, Copper slip I think because one major manufacturer brands his "Copa-Slip") This is a very high melting point grease with ground copper in it which is very good at both stopping moving brake parts rusting/seizing together and damping out brake squeal. However, of late there have been reports of it interfering with ABS sensors (I haven't experienced this but I have started using a special ceramic brake grease "just in case"
On the right is Aluminium grease - like the Copper grease but for slightly different applications.
The two in front are, on the left, a modern ceramic based grease for use where ABS brakes are involved (so just about all the cars on the road today) and, on the right, silicon grease which is useful on rubber parts as it won't degrade rubber like a petroleum based grease will.
And finally. Obviously these anti-seize/anti-squeal compounds, being lubricants, must be applied sparingly and NEVER where they can get onto the friction faces of the brakes (the disc itself or the front face of the pad which grips against the disc!) A light smear on the metal back of the pad where the caliper/piston pushes against the pad and on the lugs where the pad locates in the caliper will often work wonders with stopping brake squeal and, because it keeps things free moving, gives nice, smooth, progressive brakes. I would warn again though not to let it anywhere near the friction faces. It's tantamount to pouring oil on your brakes which would be disastrous!
Probably better if someone can show you first time you try it but there are also some excellent You Tube videos and I bet there'll be a "How To" somewhere in our forum
Hope all this is helpful please do get back to me about anything
Kind regards
Jock
Just thought you might be worrying after my dire warning about "oiling" your brakes. It's not good to let oil anywhere near brakes for the obvious reasons but also brakes get very very hot and oil gets thinner and thinner the hotter it gets so will spread itself out over a large area. Unlike the specialized high melting point greases designed for use in brake work. However if all you've done is rub an oily rag over the centre of the hub so that just a hint of oil is left behind - not applied actual liquid oil from an oil can - you should be all right (and it will make getting the wheel off easier next time of course)
Cheers
Jock
Thanks Jock
all your tips and comments are much appreciated, and it's not patronising. A change in circumstances has given me more time and I have always been interested in car stuff, but never had the time to be hands on.
I like to keep my cars in good condition and hate hearing any unusual or strange noises, if it sounds different I want to know why and get it fixed. My brother is the opposite he just turns the music up, he is driving one of my old cars, got to shut my eyes and put my fingers in my ears when he gives me a lift.
The rubber puck things you spoke about are already ordered getting them for my axle stands too. Your diy ones are pretty good and do the job fine.
Goodnight all.
Hi Il Karro. I came across this video of a chap changing his pads and discs which I thought might interest you?
It's far from a perfect example of how to do it, for starters I don't like that he seems to be working just on the cheap "suicide" jack that comes with the car - and you can see it wobbling from time to time - But it does show anti-seize/squeal paste being applied. Where you see him using the wire brush in his power drill to clean up the hub you need to know that it's actually the flat surface (where the 4 wheel nut holes are) that needs to be super clean. Any grit or serious rust left here, so it gets trapped under the new disc, will make the disc wobble and give you grabbing brakes. I like to put a VERY THIN smear of anti-seize on this face (between the hub and disc) so it won't rust in place - I've seen discs so badly rusted to the hub that they would not come off with hammering and had to be cut off with an angle grinder! - Bashing 10 shades of s*** out of a very badly rusted on disc is not a good idea anyway as the shock forces will be transmitted to the wheel bearing and you might damage it.
Regarding working on jacks, especially the type you find in the boot. Quite apart from the severe injury you can cause to self or helpers if the car lands on any part of the human body is the fact that, if the car falls off the jack with the wheel removed, The bottom of the car will now be too close to the ground to get the jack back under the car! If you really have to work this way though, perhaps at the roadside away from home, put the wheel on it's side, under the sill. Then if it all goes pear shaped, the car will only land on the wheel so it won't crush you or prevent you getting the jack repositioned. One of the few good uses I can think of for a spacesaver wheel is that it's often thin enough that it will fit on top of the car's full size wheel under the car so reducing the distance the car will fall if the jack fails!
Regards
Jock
...Removed the lug nuts and the wheel was stuck, used a mallet to thump wheel at alternate sides and it eventually came off...
This is why, when I get a new car with alloy wheels, I take the wheels off almost as soon as I get it, and apply a thin smear of anti-seize grease to the face of the hub that the wheel is in contact with: https://www.fiatforum.com/panda-iii/436409-what-did-you-do-your-panda-today-61.html?p=4352105
Well worth doing, especially those of you with recent new cars with a spare wheel. Nothing worse than having spec'd the spare tyre but not being able to use it on a cold, wet wtinter's night when you get your first puncture, because you can't get the old wheel off. :)
Yes I totally agree preparation is everything. Been kinda busy so car on hold at the moment, although ordered some copper grease on Puggit Auld Jock's recommendation.
Hopefully get back on track this week and organise it's service. Will keep you all updated.
Il Karro
I buy Car Mechanics magazine every month and in the current edition, on page 25 "Tales from the workshop" there is a wee feature on a Vauxhall Zafira which had, after a visit to a "fast fit" workshop where it's discs and pads were replaced, developed exactly this problem. When the brakes were stripped it was found that the hubs had not been cleaned before the new components were fitted so the discs were "wobbling" slightly. Not a lot but enough to cause a judder under braking. Irregular wear to the new discs over the few months of use before it was taken to the writer's garage meant that even after cleaning the hubs it was found the discs were not reusable so new discs and pads had to be fitted! They don't say if the customer tried to recover costs from the "fast fitters" but I suspect he/she won't be returning.
Looking at that video again I just realized he seems to be working on a dirt floor. Not a good idea. Unstable for the jack and greatly reduced grip for braked/chocked wheels which increases the chances of the vehicle moving and falling off the jack! Actually I've been trying to decide exactly how he's got the vehicle supported? If you look closely at that "suicide" jack it doesn't seem to be quite in contact with the sill? is the car resting on that wheel under the sill a little further back? maybe not? So what is holding it up?
Here is my update for today, car got serviced today, looking for some feedback on the price and any comments.
Went to a local garage that my cousin's son takes his Fiat 500 too. It is his pride and joy, he does a lot of work on the car himself but also uses this garage, so I figured if he trusts them I'll give them a try.
Stopped in at garage and chatted to guy, told him that last service was in 2017 with 1470 miles on the clock, and that I was looking for an interim service and the mileage was at 3700. Would also like my brakes checked, explained that I had looked at one of the rear brakes, and thought they looked okay but had a problem getting wheel off, probably due to the fact that car had been sitting.
Left the car with them and got a call a couple of hours later to inform me that the front brakes were badly pitted, corroded and needed replaced, told them to replace with Pagid ones. They also had problems with the oil sump and said the screw was quite loose when they removed it because the thread in the oil sump was stripped.
I informed them that there had been no signs of oil leaks on my garage floor and asked them if the screw had been over tightened previously or what had caused it. They couldn't really say but were going to try and re tap the thread and if that didn't work, it would be a new oil sump, that wouldn't arrive until Friday. Thought to myself I could manage if car was off the road a couple of days if need be, then they told me it was a relatively time consuming job to replace sump and the price tag of a new oem oil sump was hefty too.
So whilst I waited with dread on another phone call I contacted my local fiat garage and queried price of new oil sump, and labour charges to get it replaced here are the prices
oem oil sump £328.15
3 hours labour £315 +VAT
and of course replacement oil
after I picked myself off the floor and came round I anxiously waited on the phone call. The re tapping had worked and the thread was tight. The car could be collected. Not really sure if I 100% trust the re tapping but fingers crossed for now.
So I collected the car and paid the bill which can be seen below, so all in all it was a dramatic day for Pingu and myself, but the bill could have been a lot bigger. So have a look guys and tell me what you think.
Oil filter bit pricey, I've bought myself and passed to mechanic (£8). Last time I left him to it (only £13.50). The oil isn't the right stuff but better than the valve gear bathing in treacle. If you get the issue I have post oil change with misfire and limp home mode, don't take it back. Thrash it really hard in low gears, cured mine. Brakes could be lack of use. You still need air filter, pollen filter, spark plugs and another oil change at some point.
They're not fragile cars but need keeping on top of. Oil changes paramount because they're cheap compared to Uniair unit or a secondhand engine.
PS bill suggests they put 3 litres of oil in. Can hold another 0.2-0.5 litres. Don't put any more in if plan on having done again. Keep enjoying. :)
