Technical Panda 2019-alu wheels without retaining screws?
short question,
can I mount alloy wheels with retaining screws dismounted?
I ordered set of brand new alloy discs, all specs are exactly the same as original sheet wheels, and discs are officialy certified for a Panda 312, wheels fit lovely and tight - but dont have extra cut-out for that pins (need to be removed). Could any trouble/misunderstanding happen? (vehicle is in warranty).
What about tightening? Certificate is saying 90Nm, is that allright?
https://proline-wheels.de/en/collection/vx100/ in black
short question,
Hi.
The threaded pins actually hold the brakes in position
They do NOT help to align the wheels ;)
What you COULD DO..
Use a plain bolt.. just a thread and hexhead.. no spike (older FIATS had 1 of these and 1 spiked)
Then you can drill a small and shallow hole in the alloy wheel to clear the small bolt head :)
Thanks for answers,
I know which bolts you mean (had them on Sei) but drilling into brand new wheel, is not what i want to try :D .
I was digging and complicatedly translating through that TUV certificate (german which I dont speak), and its already mentioned there:
"B02 - Vor Montage der Räder sind eventuell vorhandene Zentrierstifte, Befestigungs-Schrauben oder Sicherungsringe an den Anschlussflanschen des Fahrzeugs zu entfernen."
="Before mounting the wheels, any existing centering pins, fastening screws or locking rings on the connecting flanges of the vehicle must be removed". (n)
so definitely it was tested and approved to work without them.
Hi.
Once the wheel is on, it clamps the disc to the hub very tightly, a small bolt like that is really only there to hold the disc when the wheel is removed. Only a disc with a dished retaining screw and the disc with a chamfered recess for that bolt will have anything to do with reducing eccentricity of the disc. It will be fine less this bolt.
If this really worries you about runout (eccentricity) then remove the caliper and disc and screw in a stud of sufficient length to be flush with the disc edge when fitted.
Eccentricity can be felt on the steering when braking at speed.
The wheel will centre on the ring on the hub. But without this small bolt the disc could turn a little with the wheel off (normally rust will prevent that) and the boltholes could not completely line up, making returning the 4 bolts holding the wheel (and disc) a little more challenging. But you will be fine without them.
gr J
If it were me..
I would want SOMETHING holding drums :disks in place
Nothing stopping you countersinking the mount holes and using a countersunk bolt :screw
So wheel will mount perfectly
( I use a threaded piece of 12mm bar..
Screw into hub
Slide wheel over the bar.. keeps it all together while you get 2 wheel bolts in place )
If it were me..
Screw into hub
Simple ideas often the best. I will add same to my tool kit. On a dark freezing night it might make the wheel change so much easier. Thanks.
They were developed for cinq:sei sportings
As my old lampredi era cars had a decent amount of space for ME to prop the wheel in the right direction
I will have to add photo's ;)
Get a bolt of the correct thread and cut it to the correct length and then cut a slot in it for a screwdriver. Then just screw it in with threadlock so its level with the drum. Job done!!
Ive been thinking of cutting a piece from thick rubber O ring.
But is that needed at all?? :chin::chin: What gets in - will get out down the drum, its not water-tight....??!...
What do you think?
What do you think?
I'd be concerned about spray from the road especially on winter with the salt over time causing corrosion build up inside
I have different set of sheet wheels for winter used together with retaining screws, Iam only worry of some water splash/dust from summer season
Well .. as weve been debating this for a while ;)
Hold the brake drum stationary..
Rotate the hub 90 degrees
You should have 4 large holes.. wheel bolts
2 blind holes.. where the small pins were
Great idea!! I know where are you pointing but I want to avoid this, because (it was mentioned above in this topic) while moving with drum some dirt/rust could get between drum/hub contact area and will make worse..??..
But its far the most painless and easiest method I think, together with removing drum completely and cleaning inside as well? Is there any problem with ABS ring/sensor while removing drum??
