Thanks the illegal bit is an issue and odd Any other ideas for brighter than standard bulbs?
LED side lights are fine and look a lot better
The front plastic gets very scratched which scatters a lot of the light. A good polish will fetch them back along with a good alignment.
Quality of the bulb fitted makes a big difference. Just changing from pound shop dim glowing ones to standard Ring is noticeable. Some of the cheap bulbs also puts the aim way off. So how to improve and by how much is going to depend on your starting place
I have never put extra bright bulbs in. There expensive and have a shorter life
Pretty sure someone in this section fitted some with good results. No doubt a search should pull it up. Over a year ago me thinks. Worth finding as from memory they were getting over a year out of the bulbs and named the brand.
I have Just look up the retro fitting led bulbs and illegal. Some of the answer range from stupid to dangerous. As an example someone wrote as long as they aren’t blue there fine.
You can look up the regulations on the government department of transport site. Basically unless the car was originally fitted with LEDs or is a projector type headlight it’s a no go. The question has also been asked and answered on the uk police forum also.
