Technical Panda 100hp metal tapping noise front end
zeppelins
South East
Have had a metal tapping or rattling noise over rough ground coming from the front end ever since I got her 6 months ago.
Just had the drop links and anti roll bar bushes replaced and it's made no difference. The garage said the next culprit might be top mounts, however I had the shocks and top mounts done by another garage when i first bought the car. I mentioned this to the garage diagnosing it now and they said maybe the mounts were installed incorrectly.
Has anyone else had a sound like this and managed to identify it. Once the car is at speed the rattling is pretty much constant as there is no such thing as a smooth road round these parts. Attached a video is as close as I can get to replicating it.
Thanks in advance for any help.
Model
100hp
2006
  • 20250710_200711_1.mp4
    11.5 MB
It's hard to let in the video
Definitely sounds like a metal to metal contact to me
Standard suspension or.lowered
The chassis side of the arm does not appear to be in time with the back of of the wheel arch
Take video of the rear bush and look for vertical movement
I would have thought a garage would have spotted this though
Could be the angle but this does not look right
Tantalisingly short and full of moving shadows , I had it on loop and you just can't make it out before it's cut short
I see what you mean there, but it could be the shadows playing tricks
Thanks for the replies so far.
Video was taken as the light was fading so I'll try and set up a better angle with more light tomorrow.
Recent MOT with advisor:
  • Front Anti-roll bar pin or bush worn but not resulting in excessive movement (5.3.4 (a) (i))
Standard suspension set up
Sounds like a noisy strut valve,
or possibly anti roll bar bush.
I would check the spring is seated properly and the strut top bushes are correctly oriented - this can cause noises- and just monitor for a while longer. Maybe also check steering rack inner bushes and column pinch bolts. Maybe replace the lower ball joint pinch bolt.
Seeing Koalars post soak the ball joint to arm with oil. Do 1 thing at a time. Then soak arm bushes with silicon spray 1at a time. See if you can stop the noise. But 1 thing then try it for a day before doing the next bush.
I still think strut valve. Loose strut gaiters and some aftermarket brands can make all sorts of noises too.
EDIT. track rod end looks to be moving, could be that too.
Going to try and take a better video over the weekend when I can enlist some help. Will try the suggested lubrication too.
Meanwhile, do you think the shock mounts could be out of place? I noticed on one side there are what look like an attempt at alignment markers (my best guess, I'm not very mechanical) that are very far apart.
And on the other side no markers at all.
Same answer as here
*Update*
Over the weekend I tried to make a better video in the garage with better light and less sound pollution. In doing so it seemed to isolate the sound, sounded like it was coming from the springs/shock area.
Took her into the garage today and the garage took out the shocks and springs. They found that the springs (which look aged/possibly original) were barely sitting on top of the shocks. And we're rattling around against the circular metal base in the picture here.
He tried putting some new MK shocks (apparently compatible) and the result was the same. So he's getting some new springs in tomorrow to see if that makes a difference.
Has anyone else had this experience?
  • 20250712_122608.mp4
    13.1 MB
Check it's got the right strut fitted, they are unique
Should be a label on the stut,.just an example not the 100hp
There's not much pressure on the springs, how's it compare to the other side which doesn't tick
Can we see a video of the rear of the suspension arm and or ball joint with the camera still
