RobCa
Hi All. Advice please.
I've got a 2005 1.1 Panda and I've been getting P0300 & P0302 codes lately. I've been working through the possible causes, new plugs, swap HT leads around, swap the 2 coils around and swapped cyl 2 & 3 fuel injectors around. No change. Engine light not on.
My next thing was to check the compression. The Haynes manual was not too specific about what to disconnect so I disconnected the injector plugs, both coil LT plugs and the 2 plugs to the throttle body before turning the engine over with the spark plugs out, to test.
Now with it back together, as well as getting P0300 & P0302, I'm getting P0120 (Throttle pos sensor), P0201-4 (all 4 injectors) and P0505 (Idle air control sys) with a permanent engine light!
Have I damaged the ECU turning the engine over this way? Checked all fuses in case it was something simple like that!
