I purchased a 2010 1.3 mjtd earlier this year as a non runner. Plugged in and it came up with the p0657-16 open circuit a fault.
Traced things through and discovered the fuel pump relay in the engine bay fusebox had popped. I replaced it and everything fired up perfectly and drove well.
I parked it up for a couple of weeks and put some diesel in it.
Now it won't start at all. There is no power to the fuel pump.
I've tried another ecu set from my other qubo and it works fine on the other vehicle. All relays seem to be ok.
There hasn't been a live feed from the ecu to the fuel pump relay. Using multiscan the code p0657-16 comes up. When it's cleared the fuel pump in the tank primes but it won't start.
The fault code comes back after a few tries at starting.
What sensors are in "circuit a" that might be faulty?
Has anybody else had this problem and managed to fix it?
