General P0402-61 AIR TRACKING CONTROL SYSTEM - SIGNAL CALCULATION FAILURE
Ecocarstore
Birmingham
P0402-61 AIR TRACKING CONTROL SYSTEM - SIGNAL CALCULATION FAILURE​
1COMPONENT CONCERNEDCHECK FOR LEAKS DOWNSTREAM OF THE FLOW METEROK (NO FAULTS DETECTED)FAULT DETECTEDOPERATION
2COMPONENT CONCERNEDFLOW METER SUPPLY CHECKOK (NO FAULTS DETECTED)FAULT DETECTEDOPERATION
3COMPONENT CONCERNEDEGR VALVE OPERATION CHECKOK (NO FAULTS DETECTED)FAULT DETECTEDOPERATION
4COMPONENT CONCERNEDFLOW METER OPERATION CHECKOK (NO FAULTS DETECTED)FAULT DETECTEDOPERATION
Test results
Inlet ductCheck for leaks in the intake duct downstream of the flow meterGo to Step 2LeaksRestore the correct operation
Flow meter power supplyCheck that the flow meter supply is correctGo to Step 3Power supply not correctRestore correct power supply
EGR valveConnect the diagnosis equipment, and check that the EGR valve is working correctly in "actuators" modeGo to Step 4EGR valve not working correctlyReplace the EGR valveOp. 1080C24 E.G.R. SYSTEM SOLENOID - R + R
Flow meterCheck that the flow meter working correctly by carrying out theSee Test 1060GS FLOW METER OPERATION CHECKEnd of diagnosisAir flow meter not working properlyReplace the air flow meterOp. 1060G10 AIR FLOW METER - R.R.
