Technical P0170 and P1170 error codes
Finland
Hi!
Already tried another throttle body, fuel rail with injectors and lambdas but no go. Was worse without first lambda. There was no pressure in the fuel hose, should it be like that? Feels like lack of fuel, takes time to start. Should I test new map sensor next? No check engine light.
P0170 mixture strength signal low
P1170 mixture strength minimum lean fuel
