Hi, Im looking for some help regarding an overheating problem with my punto.
I drove it to work yesterday and i noticed the heater was only blowing in cold air, I just ignored it and thought it strange. About 20 minutes later i noticed the engine temp has rising up past the 75% mark and was climbing steadily.
I got it into the car park just as the red temp warning light came on. I cursed the gods and went about my days work...
After work i started the car it was puffing a little which i have noticed it going in the past few days (it needs a serviers, i reckon a new set of plugs for a start will see the end of the puffing) and i started to drive it home, i told myself I'd pull in as soon as it over heats and let it cool and take the drive home in this manner. However, the car did not over heat and was blowing hot air from the heater as it usually does. I got all the way home on the motorway with engine temperture at normal.
When i pulled left into my estate i noticed the heat had stopped and and the temp was rising, I pulled up outside my house and watched it climb. Turned off the ignition and opened the bonnet. Coolant seemd fine, nothing out of the ordinary. I let the car cool down and a friend at work had said the problem sounded like the head gasket or an air lock in the cooling system.
Now that i think of it, there has been a gurgling noise coming from the car over the past few months when i'd start it up. My brother had said it sounds like an air lock at the time (again i thought nothing major of it, the car still worked)
Has any body got any idea what the over heating problem might be other than, the Head Gasket going or an Air Lock in the system? The car is a 00 Punto ELX.
Mike
Mike
