kazherineco
I have a 1.1 petrol Panda that has had a few problems since I bought it back in November. I changed the spark plugs after she showed a lot of juddering and rev drops while driving. The amber engine light comes on and according to OBD it's a P0202 open cylinder on injector 2. I replaced the injector, warning still there, jiggled the wiring, cleaned the sensor and reset everything. Also replaced zip-ties on the ECU connectors holding the mountain of wires together that feed into them. Problem solved.
For about a month or two. Now the engine light is back on and same code is showing up.
I've cleaned the injector, fiddled with the wiring, and done the spoon-handle method to hold the wiring up at the ECU connectors. I'm hoping this fixes the issue. Won't know until I drive the car however, and the roads are very bumpy which is a problem for keeping things steady in the engine area.
If this problem persists, what's the next course of action for me to take? I don't want to have to mess around with the wiring harness but can't get an auto-electrician out for another two weeks yet. Any little things I could try and do in the meantime to hopefully solve the issue?
I saw something about a y-split in the wiring harness near the injectors that might be causing some of these problems for me.
Other than the fault an engine juddering as the ECU tries to fix the "problem" when driving, the car is great. Runs like a dream when its not having a fit via ECU and P0202 fault.
