Technical Only sidelights come on, full and dipped beams not working:(
Zonkazoid
St Albans
When i turn the headlight knob two clicks, to where the dipped beams should come on, the full beam light on the dash comes on but only the sidelights actually turn on!
I've had a look at the fuses and bulbs but all seem in working order, anyone know what could be the problem?
Joe
You'll have to trace the wiring from the fusebox and see where all the joins are and check them. I had something similar once (not on Punto, so I can't help much) and there was a large connector block with about 20 wires going in.. the headlamp pins were slightly corroded.
Are you sure it's not the switch itself (does "flash" high-beam work)?
Probably an Auto electrician will be able to find the problem in 20 minutes.
Ralf S.
Cheers Dude
I don't think its the switch, not even the flash works. I've had a look and some of the connections look a bit dodgy so i'm going to get hold of some new ones and see if it helps!
Joe
