Cheddar Man oh aar that'll be it then Joined Nov 8, 2005 Messages 16 Points 5 Location Somerset Nov 8, 2005 #1 Hi, hope someone can help - got a bad case of crankcase fumes in the cabin after about 15 minutes on the road...any ideas please? CM :yuck:
A arseofbox Principality Retained :) Joined Jul 16, 2003 Messages 6,978 Points 1,063 Location Midlands Nov 8, 2005 #2 899cc or 1108cc? Id reckon the breather's come off the rocker/ cam gear cover, cos I know mine is loose, and I do get the occasional whiff of oil (not major at all..)
OP OP Cheddar Man oh aar that'll be it then Joined Nov 8, 2005 Messages 16 Points 5 Location Somerset Nov 8, 2005 #3 sorry, 899cc. whereabouts is the breather pipe? between engine & bulkhead? I've got a Haynes but it doesn't help much. ta. CM
C cm246 Patron member Joined Dec 1, 2004 Messages 190 Points 76 Location London Nov 8, 2005 #4 the pipe is comming out from your left hand side of your filter box and connects to the engine next toe the oil cap.
OP OP Cheddar Man oh aar that'll be it then Joined Nov 8, 2005 Messages 16 Points 5 Location Somerset Nov 14, 2005 #5 yup, found it - was leaking at the rocker cover end, the Fiat clip wasn't holding tight. Now secured with a jubilee clip. New std air filter fitted, no more smells yet. CM
