Technical Oil Sweating at Turbo ?
reido2
Sunny Glasgow
Hi, just had the timing belt kit fitted & water pump replaced plus a 5th year service carried out. One of the advisory notes was "oil sweating at turbo", is this something to be concerned with and what would be needed to rectify this ?
Cheers in advance.
Cheers in advance.
Depends how much oil there is, try cleaning it off and keep an eye on it, do you have to top the oil up by a lot weekly / monthly? Presumably the sweating is at the joint between turbo and the hose at the joint where those horrible cheap n nasty Fiat clips clamp the pipe on? That may be on the loose side, a good quality worm drive might cure that, all depends on how much oil sweat and over how long.
