Technical  Oil leak!
Technical  Oil leak!
yes!
we've had to top up the oil in ours twice now! it once managed to leak bone-dry on a motorway journey - absolutely bizarre!!
it doesnt leave a drop on the driveway so one can only assume its happening under pressure. the coolant is clean so the head gasket must be fine. its mechanically sound, i cant point my finger on it. even changed the oil, sump nut, etc but it still does it.
steve (confused) :p
I had the same problem, mine turned out to be a tiny pin hole in my rusty sump. apparently the sumps rust and thats common.
£70 later a new sump pan, sealer and some 10w40 and it was all fixed.
