Technical Oil leak
Technical Oil leak
mr wizo
United Kingdom.
Right i have an oil leak that is coming from around the sump - gearbox join, and its comming out from behind the flywheel plate, i have had the sump resealed and the rear crankshaft oil seal replaced but its still leaking, has anyone else had this problem?, if so how have you fixed it.
Thanks for your help
hi!
I have exactly the same problem with my car!! Take it you've fixed it now seen as tho u posted in march!!?
What was your solution.....if any?
Lea
Either the crankshaft seals haven't been done properly, or the leak is gearbox oil from the input shaft seal. Smell the oil to find out which it is; engine oil smells slightly of exhaust fumes whereas gearbox oil smells like rotten eggs! (Yes, really!) [xx(]
<font size="5"><font color="black">/</font id="black"> F <font color="black">/ </font id="black">I <font color="black">/</font id="black"> A <font color="black">/</font id="black"> T <font color="black">/</font id="black"></font id="size5">
<font color="navy">Punto 55SX</font id="navy">
