HornetUK
The below is where (black circle) I am finding a very small amount of oil type liquid, presume its gearbox oil, it seems to appear after at least a 30 in drive and doesn't create enough to drip down when parked. On the service they didn't even find it probably because not driven long enough to weep out, as that seems to be what it does. Is it where that part isn't sealed properly, is it the gearbox? Does the wheel rod (not sure what its called) go through the gearbox? As that part bolted on where the rod enters with 4 bolts seems to be where the oil is coming from.
Also currently no way of getting it fixed as such a tiny weep!
Anyone help / advise where its weeping from...cheers
