Technical OEM Headunit w/sub and amp, possible?
London
Hey, getting sick of how crap the stilo's dash now looks with an aftermarket single din headunit in. Looks very plain.
So ... I was wondering if anyone know's any devices, or indeed any way, to be able to connect a sub and amp to the original unit that is in the stilo? The original unit is a nice unit and suits the car, and if possible i would like it back in.
P.s. also are there any device that can also be connected for use of an iPod too?
Cheers.
Stuart.
yes to both.
you need a line level converter for the first, and one with aux input for the second.
i did this a very expensive but high quality method using a Rockford Fosgate 3sixty.2.
you can also use a 3sixty.1 which is less complicated, or a JL Cleansweep.
cheaper option: Kicker KQ-9 (which I also used, but has no aux input)
http://cgi.ebay.com/CLARION-EQS746-...temQQimsxZ20090501?IMSfp=TL090501125007r23423 (awesome, but needs an additional rca/line level converter)
alot of amps have a high gain input built into them, so you can just wire that into the front or rear speaker outputs.
yes to both.
How would you wire something like that? And where would you mount it?
Cheers.
