Technical Odometer is flashing..
JugsMugs
Guys I need your help. I bought this new android head unit, I installed it and everything seemed to work just fine but I realized that the mileage startet flashing. I got the obd cables from ebay and performed a proxy allignment but it couldnt connect to the Entertainment Telematic Node (ETM) and I got a timeout message. It finished the allignment however the mileage didnt stop flashing. I believe there is something wrong with my Blue&Me module. Would disconnecting the module fix my problem?
I know what it means but noone really knows how to fix it? I mean if somethings wrong the only things theyll tell you are "disconnect the battery" or "do a proxy allignment" and I did that but it couldnt connect to the ETM however there is no error message:
Body Computer (BCM/NBC): EOL Ok
Motorsteuerung (ECM/NCM): Ok
Elektrische Lenkung (EPS/NGE): Ok
Instrumententafel (IPC/NQS): EOL Ok
Bremsanlage (ABS/BSM/NFR): Ok
Knoten Schleudern/Seitenbeschl. (NYL): Ok
Knoten Airbag (NAB/ORC): EOL Ok
Knoten Convergence: EOL Ok
Entertainment Telematic Node (ETM): EOL Ok
I also checked service and my battery and thats not the problem so what is it then?
