My cinq has started making the odd one or two odd noises.
One is a low humming that changes with speed (not eninge speed) and comes from the front left. I'm assuming its wheel bearings. I did notice when working on the car a while ago, some thick oil that could have been CV grease around the gearbox side of the driveshaft on that side, but couldnt see a split. Reckon their related?
When setting off, im told there is a slight grating noise when i pull away. I can't hear it in the car, or locate it. However, i'm 90% sure i need at least one engine mount replacing. Could that explain the noise, and how easy/cheap are they to replace?
The other is a nasty metallic knocking noise when the car is cold started. I'm not 100% but i think its just down to the engine vibrating more when cold and knocking on my stupidly large cold air feed.
Any ideas, or suggest greatly appreicated.
Mark
Mark
