Technical  Notchy/sticky EPS
bradford
Hi there I’ve got a 2004 1.2 8v with 165k that’s not been on the road in 5 years. Recently it’s had a new clutch & hydraulic system to get it roadworthy as a second run around.
Since I’ve been driving it this last week, I’ve noticed the power steering feels unusual (compared to my Tipo Cross at least). Whist there are no warning lights or fault codes for the EPS, there is a notchy/sticky feeling to the steering. This makes it more difficult to keep the car in a straight line on motorways for example. It’s reluctant to return to centre too from a small amount of lock. I vaguely remember this being present prior to placing it in storage. At a standstill when you rock wheel side to side you can hear the motor groaning quietly. I’ve done all the system recalibrations via Multisacan and it’s made no difference.
Given the car is worth next to nothing, I may go down the route of replacing just the motor or the entire column with a second hand one (if I can find a low mileage one). I’m well aware of the documented faults with the panda EPS and I’ve rarely had any bother from mine.
My question is - are the EPS columns programmed to each vehicle? Or are they plug and play.
Do you just think this at motor fault as opposed to any other components?
Second hand ones are around £100ish and I know remanufactured ones £300ish.
What are your thoughts?
Rusty top mount bearing would be my guess
Is it worse at higher speed by any chance
Yes the column is plug and. Play, as long as they are taken off and out back with the wheel pointing straight ahead
I doubt it will need a EPS car sat for 5 years will almost certainly be mechanical
Lift the front wheel and turn the steering lock to lock with the engine off would be a sensible first step
Unfortunately it will not show up everything, as the suspension isn't under the same weight and load
A better way would be to use some turn plates, but not the average kit for DIY
Its been in dry storage for all that time and the battery charged every few weeks. The front suspension had an overhaul around 20k ago with new Bilstein B6 dampers and top mounts. Could it be down to lack of use?
Yes
Dry storage as in a cold garage or heated room
B6 are normally horrid on rough roads
Is it worse at high speeds, or at parking speeds
Yes
Cold garage.
Its worse when I've been driving for a while and faster roads where you need to make small inputs to keep in a straight line. It feels like the EPS motor doesn't want to cooperate.
EPS is proportional to speed the faster you go the less the EPS assist, at 50 mph it's almost none existing
99% something mechanically and not the EPS
If you want to eliminate the last 1% you could always pull the EPS fuse, they drive fine at 50MPH and above
are we saying the steering is stiff and notchy
Or
Is the car wandering when driving in a straight line
We're the suspension arms done
Or
It just has an unnatural feeling. It’s not stiff just notchy as if the motor is sticking. The car doesn’t wander. The suspension arm were replaced at the same time
Post 3
With the front wheels off the ground, engine off
Turn the steering slowly a few degrees each way as if driving down a straightish country road
How does it feel
Almost certainly something binding due to being layed up for 5 years
You already 95% confirmed it's not the EPS as it's worse on faster road where there virtually no input from the EPS, if you want to eliminate the last 5% pull the fuse and take it for a test drive, slower speeds are fine because the EPS is giving the most assistance and masking the binding, unless the fault is tramlining in which case it likely to be suspension arms
You could try the city button and see if that makes a difference
My guess would be top mounts, yes I know they are new, or UJ joints in the steering column
But without any feedback from any diagnostic or questions it's pure guess work
