Not building media library
trini
I will need to put new lectures on my USB flash drive so I can listen to them in the car. The problem is that the B&M is not recognising the new files and is failing to build a new library. How can I allow new mp3 files to be loaded into the media player?
durukan
istanbul
try formatting your flash drive (after you backup your files) and change titles of your mp3 files, make them as simple as possible (like "lecture 1").
rangdo
Gronda Gronda
Rochdale
Based on experience of the USB in my 318, try renaming the flash drive itself. Sometimes when I add new albums to my drive it doesn't always index them correctly, apparently it caches the last 4 devices based on the name of the device.
So when I update I include the date in the name, something like SSD_110304 - the car thinks it's a new drive and builds a new index.
jimm120
Athens
you have 5.5 version,i have the same problem............and the simple answer .put in the usb slot a new one flash pen,add one track-then replace the new one with the old one, and you'ii have all the new library......................until the next version to work properly :worship:
