My little punto has decided that it doesn't want to start! I turn the ignition and it turns over very slowly (60 rpm).
Initially I diagnosed this as a starter moter issue as i thought the motor windings had decided that life was just a bit too much, so 1 new starter motor later... engine still turning very slowly. I removed the spark plugs (just for kicks) thinking that without compresion it might spin a little faster... no such luck.
It's not a battery issue (multimeter reads 12.6V and just in case I tried jumping it aswell)
Previously I've had the standard head gasket issues associated with this engine, continued to loss some water so was running it with head gasket rad-weld which stopped the water loss.
Whilst the engine is turning (very slowly) I am hearing a squeak from the cam belt end of the block...
Could this be a stuck/disintergrated water pump?
Any help would be much appreciated
