Technical noise??
Technical noise??
mike_manc
hello there had my fiat coupe for 4 months now and i`ve had all the essentials done cam belt, clutch full service ect ect.. just recently i`ve started to hear a whistling noise as i accellerate and it gets louder sounds like a siren i keep thinkin im about to get pulled by the fuzz any ideas????
other than that the engine runs sweet as a nut!?!?!
FDF
Marea Scrappaged :(
In my head
Did the whistling start just after the service?
I used to have a car that started whistling like that, turned out to be a faulty air filter.
bridges
Here to help
Lincolnshire
Is worth a visual check on the airbox as you sound to have an air leak, a loose hose clip or the box not clipped together 100% Undo the airbox check the filter and put it back together (y)
OP
OP
M
mike_manc
yeah has a dump valve dont know what brand though...
found a crack in a hose wahoooooooooooooooo!
