Technical Noise Shifting into Gear - Automatic
BIGBAND39
Cranston, RI
As I try to navigate through the myriad of issues my Fiat seems to have, I came across another curious problem that I can’t seem to figure out. When I shift from park into any gear and back I hear an unsettling screech or squeal. I tried to record it here…..
Any ideas everyone?
Hi, did you manage to get to the bottom of this?
My 09 automatic is doing the same- it’s really loud when driving and hates going into reverse. The whole car ‘clunks’.
Just had the solenoid transmitter replaced at a garage but have had to take it back as this hasn’t solved the problem (just left me with a massive bill…)
Many thanks.
Many thanks.
Hii were you able to find out what was the issue ??
Hi all
Just like to clarify
The Mexican built US models are an Automatic
The Italian build UK models are a manual gearbox and a 'robot ' works the clutch and gears
Totally different to fault find..
Always worth scanning the Body computer AND gearbox for error codes and wear parameters before going to a Dealer of specialist
