Technical noise front end not listed in faq's
shnowzy
lancashire, United Kingdom.
just fitted a anti roll bar, new back box and clutch cable to my sx cinq but dont think this noise is a result of that
when i accelerate nothing but when i take foot of gas doing about 40 hear a rubbing/grinding noise from the front passenger side
ne1 help i dont think it is wheel bearing as i could hear that all the time right?
me thinks stone or something in brake pads
national tyres meant to check it but blamed roll bar dont think they checked my brakes
ne sugestions appreciated cheers [8D][8D][8D][8D][8D] MOT on thursday
Rear Gearbox mount sounds shot, Only about £12 from Fiat, this is causing your exhaust to rub against the Anti-Roll bar when you lift off the throttle. easy job to sort on a lazy afternoon:)
sorted it think it is this problem
https://www.fiatforum.com/forum/topic.asp?TOPIC_ID=7207&SearchTerms=brake,noise
eliminated wheel bearing as not when cornering ect
engin/gearbox mounts ok no play there
something rubbing on brake going to kwack fit after
are punto brakes similar?
