I have replaced the engine of my seic to and 1.2 MPI 8v.
The ecu is the ECOL version without the keycode.
I have used the Original seic engine loom with the 4 injector connectors solderd onto it.
Today I finished the engine and started it.
It sounds great, nice and steady.
The radiator get warm but the fan does not kick in.
After a while the warning light at the bottom right of the panel turns on.
Not very bright but still.
I turned the engine of an shorted the wire that connects to the sensor in the radiator with a paper clip.
The fan started so I thought the sensor was faulty.
I replaced it but still no success. Fan does not kick in.
Also the paperclip get extremely hot, burned my finger pretty bad
Even with the fan running the warning light turned on when running stationary.
As the car has no gauges for temperature I connected the laptop with the MultiEcuScan. But this does not detect the ECU?
There must be something wrong somewhere as the fan won'n kick in.
Also the fact that the paperclip gets so hot indicates that there is a lot of resistance on the wire. Possibly causing the fact that the fan won't start.
I hope you guys have some ideas as I don't know where to look anymore.
