What coil goes in th 1981 fiat 124 spider 2000 electronic ignition, please? Can i use a
12v universal coil, or get one out of a junk car from pic n pull junk yard? Thanx 4 any help.
i Dont want to pay $80 for a new one to find out that may not even be th problem. When I got th car, i diagnosed it to find out it had no fire. So i replaced th coil with my 68 mustang coil, bought new: distributor, igniter/control module, plugs, n sparkplug wires. It started n ran for 30 seconds, i shut it off because it sounded like it was 180◦out of time.
I installed distributor to #1 cylinder at tdc on compression stroke. Chiltons says rotor is to point at #1 tower of th distributor .
i've heard fiats are to set to th #4 cyl tdc SILLINESS, What,why,who,when? Come on really fiat! is this true. ? For cryin out loud.
I Let it sit for 2 years. Cranked it over n got a no spark issue. So i pulled th coil wire out from th distributor n set it ¼" from th ground of th hood latch n saw no spark. Th coil did work 2 years ago. Now NO Fire. Piece o fiat.
1. Can th coil be bench tested?
2. Can th igniter/control module be diagnosed w a multimeter?
3.What coil will work in th 1981 fiat 124 spider 2000 with th electronic ignition, please?
4. Can i use a 12v universal coil, or get one out of a junk car from pic n pull junk yard?
5. Are fiat 124 spiders really set to th #4 cyl
@ tdc?
Thanx 4 any help.
@ tdc?
Thanx 4 any help.
