No wig pulling from as I haven't got much to pull
The car is a nut and bolt restoration that once finished has been parked for 4/5 years so I'm expecting seizures so today I will removed the master cylinder and start there with the pedal being so free.
As for the rear callipers, it is a single line the rear brakes that goes through a compensator so I suppose there could be a problem there in not letting fluid to the LH rear, any thoughts from anyone familiar with the 124 ?
There is one hard brake line to the rear brakes, this goes from the master cylinder to the brake pressure regulator valve (aka a compensator) , another pipe exits the brake press. regulator. and goes to a flexible hose and this goes to a 3 way union on the rear axle, 2 hard lines exit the 3 way union, 1 goes the left rear brake, the other goes to the right rear brake. The br. press. reg. valve is mounted above the rear axle and is connected to the rear axle by a linkage - as the axle is loaded the valve is held open, as the axle drops (e.g. if you jack up the car or go over a sharp rise and 'get some air') the valve closes - this is designed to prevent the rear brakes locking if you brake very hard. The flexible hose is there to allow for rear axle movement. The br. press. reg. valve is a small alloy housing, it has 2 metal (hard) lines going to it and has a rubber boot covering the end of the linkage, it's attached to the bodyshell by 2 x 13mm headed bolts. I'd leave this alone if it's working ok.
So, in summary, the br. press. reg. valve (or compensator) supplies fluid to both rear brakes so it is highly unlikely that it's a problem.
Also, if you can pump fluid from either of the rear brakes, it's unlikely that there's anything wrong with the master cylinder or the rear brake line or the compensator.
I'd check for a blockage to the LH rear brake, possible the bleed screw or the flexible hose. You might loosen the 2 rear brake pipes where they attach to the 3 way union and see if you're getting fluid from both pipes .If ok, LH loosen pipe where it attaches to the LH caliper flexible hose and see if you have fluid, if ok, loosen hose to caliper (iirc, you'll have to remove the rear caliper to do this as the hose screws into the caliper body) and see if you have fluid. If you still have fluid, proceed:-
Remove the LH rear caliper (4 little spring clips plus 2 wedges) and examine the orientation of the caliper piston - there's a deep groove that fits over a projecting pin on the back of the brake pad but there's also a small line, like a deep scratch - this scratched line should be above the deep groove when the caliper is fitted to the brake.
Reason:- there's a bleed channel inside the caliper, the scratched line indicates when the piston is correctly positioned, if the scratched line is under the deep groove, it won't be possible to properly bleed air from the caliper (I can't remember if it will also prevent fluid flowing from the bleed screw).
P.S. it would be helpful if you could indicate which model of 124 Coupe you have (AC, BC or CC) or the year of manufacture, also supply engine size (1438, 1608, `1592, 1756cc) if you want to ask any engine related questions. (on the Coupes, there should be a little al. plate on the rear of the firewall which shows the model plus other info).
