few weeks ago i started to get a grinding noise from the rear brakes, got home took the drums off and pads were down to the metal. so changed them both and that was that. day after!!! griding/ABS noise from the front left wheel area. all brakes work well but am still getting the nosie when i brake (at any speed no matter how hard i brake) front the front left wheel area. then after 5 mins of drving the ABS light comes on noise goes away but loose all ABS! so decided to take front wheels off to have a look just to see if a could find any problems with the abs sensors/conectors, all looked ok except the front left wheel sensor looked kinda suspect it was cracked. but it was late so i put it back together and left it at that for the night. morning after on the drive to work mabie 10 mins in, speedo droped buy about 20 mph then 2 secs after drops to 0, the handbrake light comes on and steering goes very light. so very annoyed and kind of blaming myself c since a had been pocking around the night before i went and bought the front left ABS sensor, fitted it and bottem line is its still doing it. If i turn the car off then start it again the speedo works for a while they cuts out but abs light constantly on and no abs. really need some help here. thanks
