I'm beginning to think I shouldn't try and build my own PC
Anyway, this is what I have:
ASUS A7V333 Mobo Rev. 1.02 (Unused, so effectively brand new)
AMD Athlon XP - Model 6 (Palomino) 2000 MHz (rated), 1667 MHz (actual)
Socket A - 1.75v 90C Max Temp 256kb L2 Cache 266 MHz effective bus speed (133 MHz actual) (Thanks to Xen for identifying them - https://www.fiatforum.com/computing/108738-fastest-processor-my-mobo-speed-current-amd-cpu.html)
Seagate 160GB PATA Hard Drive (brand new)
Crucial 256MB 266Mhz DDR Ram (for the moment)
PNY Technologies Verto Ti4280 Graphics card
Bog standard CD Rom
Bog standard 3.5" FDD
Mercury ATX 400W Switching PSU
The MOBO has been installed into a DABS ATX tower case using the supplied stand offs, and using the correct number of screws as specified in the ASUS manual. Everything else has been installed as per the book and connected correctly.
When I turn on the ATX power supply at the back of the machine, the mobo green LED lights up. I then hit the ATX power on at the front of the PC and the system on LED lights up and the HDD light flashes then goes off. The CD rom flashes its light before going off then I get an audible speech message through the computer speakers saying:
"System failed CPU test" over and over and over :bang:
The monitor doesn't come on so there's no visible error messages. At this point the PC just sits there doing nothing. If I turn off and restart the same thing happens. Also the keyboard LED's flash when the PC is turned on, but caps lock and num lock LED's do not come on when appropriate keys are pressed.
Seems that this is a common problem with ASUS mobo's - http://forums.tweaktown.com/archive/index.php/t-2371.html
What I've tried to do is this:
Reset CMOS (removed battery and shorted the two reset pins with a jumper) - no difference.
Switched from jumper free mode to jumper mode. Set system config to basic settings - no difference.
Switched back to jumper free mode - no difference.
Switched the two AMD CPU's over - no difference. Heatsink and fan correctly installed with thermal paste. Heatsink fan operates correctly when PC is switched on.
So basically it won't boot up into POST, and as a result I can't get into BIOS to set it up. From doing a search on the internet is seems that this MOBO and some others from ASUS are notorious for doing this. At the moment I don't know whether there is a simple fault that needs rectifying or if the MOBO is buggered. Or if the CPU's are buggered. Sadly I have no way of testing them
Two things that keep getting mentioned are the MOBO shorting on the case and the PSU not being the right type. When I installed the MOBO I used the suppied risers with no washers (as I was told to), but should I have in fact used insulating washers between the Mobo and case or something?
However, one clue I got from the manual might suggest where the problem lies -
IMPORTANT! Make sure the ATX 12V power supply (minimum recommended wattage: 230W) can supply at least 10mA on the +5-volt standby lead (+5VSB). The system may become unstable and may experience difficulty in powering up if the power supply is inadequate. For Wake-On-Lan support, the ATX power supply must supply at least 720mA +5VSB.
Looking at the power supply is seems that the +5VSB lead is supplying much more at 2A, so could this possibly be the problem? I've enclosed a picture of the power supply with its specs to see if this will give any clues.
I'm stumped at the moment as to what to do next. Is it a setting fault, or does it sound like a dead mobo and/ or cpu? Any advice? And if the worst comes to the worst, any recommendations as to what type of mobo I can get (that will be compatible with all my current hardware) to replace mine? And how much would I be looking at paying for a compatible mobo?
Any help and advice would be VERY greatfully received!
Bog standard CD Rom
