roby76it
New Maserati MC12
The racing version:
Wonderful!!!!!!!!!!!!!!!!!111111
Fiat Brava 1.4 12v sx
www.autopareri.com
Technical Specifications of the Maserati MC12
Roadster-type bodywork with removable hard top, two-seater, mid-rear engine, rear wheel drive.
CHASSIS
Carbon and Nomex honeycomb monocoque chassis with aluminium front and rear sub-chassis’s.
SUSPENSION
Front: double wishbones with push-rod design; progressive rate steel dampers and coaxial coils and springs.
Rear: double wishbones with push-rod design; progressive rate steel dampers and coaxial coils and springs.
19” light alloy wheels: front 9J x 19, rear 13J x 19.
Front tyres 245/35 ZR19, rear 345/35 ZR 19.
BRAKES
Brembo braking system with four cross-drilled ventilating discs. Front 380 mm x 34 mm, rear 335 mm x 32 mm; six-piston callipers front, four-piston rear with differentiated diameters. Brake pad materials: Pagid RS 4.2.1.
Bosch 5.3 ABS anti-blocking system. Electronically controlled braking corrector (EBD).
TRANSMISSION
Longitudinal rear-mounted gearbox rigidly connected to engine.
Maserati Cambiocorsa mechanical gearbox with electronically controlled electro-hydraulic operation via paddles mounted behind the steering wheel.
Dry twin-plate clutch, diameter 215 mm (8.46 in) with flexible couplings and hydraulic control.
Bosch ASR traction control.
ENGINE
65° V12
Distribution is by way of twin gear-driven overhead camshafts per cylinder bank, with four valves per cylinder hydraulic tappets.
Dry sump engine lubrication with pump in a single unit.
Integrated Bosch injection-ignition system, drive-by-wire electronic accelerator.
Weight: 232 kg
Displacement: 5998 cm3
Bore: 92 mm
Stroke: 75.2 mm
Compression ratio: 11.2:1
Maximum power output: 465 kW (630 CV*)
Engine speed at max. power output: 7500 rpm
Peak torque: 652 Nm (66.5 kgm)
Engine speed at peak torque: 5500 rpm
Max. permitted engine speed: 7700 rpm
DIMENSIONS AND WEIGHTS
Length: 5143 mm
Width: 2096 mm
Height: 1205 mm
Wheelbase: 2800 mm
Front track: 1660 mm
Rear track: 1650 mm
Front overhang: 1248 mm
Rear overhang: 1095 mm
Turning circle: 12 m
Fuel tank capacity: 115 l
Dry weight: 1335 kg
Weight distribution: 41% front - 59% rear
Weight/Power ratio: 2.1 kg/hp
PERFORMANCE
Top speed: >330 km/h
0 to 100 km/h acceleration: 3.8 s
0 to 200 km/h acceleration: 9.9 s
0-400 metres acceleration: 11.3 s
0-1000 metres: 20.1 s
The racing version:
www.autopareri.com
