Great stuff! I hadn't thought of the coil not handling 13+ volts, and it is 13.4v when I measure it at the coil. And that old orange coil gets REALLY HOT. I bought a new generic coil to try, and written on the side was 'use with a ballast resistor' which I didn't see until I removed it. Time to get a resistor.
In the meantime, I fitted the original 28IMB on the car. With the Pertronix in, the old original coil, and the fuel filter on the pressure side of the pump, the car runs. I can't say it is great, but it does drive. The high RPM miss is gone (for the moment.) The car surges, especially under light load. The fuel filter looks nothing like Vitesse' picture. Mine is cheap, plastic, vertical filter that is 1/5 full and bubbling away like champagne. So...today I'll remove and block off the return line for good and run a new fuel hose to the pump. Maybe that is causing the aeration.
Many thanks for the help. I'll be enjoying the little car soon, but only for a few more weeks. Snow season is coming.
