Technical New brakes or driveshaft? or worse new gearbox
dannufc16
hello all, just worndering if anyone out here can help with with this problem i got with my car the at the moment.
about 3 weeks ago it my car (Punto 2002 mk2) it started to squealing every time i pressed the brake, but now 3 weeks on, when i do it now it does not squeal any more but some times now it makes a grinding noise but not everytime i press the brake. work that one out:confused:
anyways now i listen out for it every time i drive it, and it seems it does it also does it when turn right, right after i have slowed down???
any help??? thanks in advance Dan:)
dolman17
Lichfield
I have the same problem. When slowing down i hear a squealing noise! I just thought it was grit or sumit on the brake pads!
It sounds like it is coming from the right front wheel. My car is the Same Punto Mk2 2002!!
OP
OP
dannufc16
i also though it was a piece of grit, but i have read so much over the past week it worrys me that it could be pricee to fix the problem, here hoping for u and me, thats all the car needs is some new brake pads
buxton the land that time
sounds like mauybe a siezed caliper causing break pad to bind slighty ? does the wheel get hot DONT toucj the break disc as you may burn yaself but does teh squeeking wheel feel warm/hoter that one on other side after driving
OP
OP
dannufc16
it aint hot but as i was driving today i could here something defo touching the disc on the drivers side and it relly sounds louder when i turn right, i.e like something on the disc catching on the pads, how much do u think it would cost cus i really have no money at the moment is it going to be pricee from what i tell ya, hope not
OP
OP
dannufc16
just had me brakes done, i had new pads and new discs from kwit fit fitted for 128.20 is that a good price????
borofan
i had same probem with the squeeling took wheel off and knocked rust off rim of disks and blew out with air line and it stopped
