right a quick update with whats going on .....
i have restored my p.c too an earlyer date all software looks fine
installed nero 7 all looks good
but sluggish but blame my overly full p.c
started spitting the dvd draw out every 4 seconds
took the drive out and hit it with a lump hammer seemed alittle lumpy when spinning the disk up but seems good lol
only joking new drive on the way should be here by tues or wed
heres what i got off the log thing that nero creates before i smashed the dvd drive if any one knows what it all means i would be grateful
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=?.?.?.?, size=30208 bytes, created 11/06/1997 20:01:02
NT-SPTI used
Nero Version: 7.8.5.0
Internal Version: 7, 8, 5, 0
(Nero Express)
Recorder: <DVDRW IDE1008> Version: 0055 - HA 1 TA 0 - 7.8.5.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <LITEON CD-ROM LTN403 >Version: DU22 - HA 1 TA 2 - 7.8.5.0
=== Scsi-Device-Map ===
DiskPeripheral : IC35L120AVV207-0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : LITEON CD-ROM LTN403 atapi Port 1 ID 0 DMA: On
CdRomPeripheral : DVDRW IDE1008 atapi Port 1 ID 1 DMA: Off
=== CDRom-Device-Map ===
LITEON CD-ROM LTN403 D: CDRom2
DVDRW IDE1008 E: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1407MB (1441264kB)
Free physical memory: 902MB (923884kB)
Memory in use : 35 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
19.4.2007
ISO compilation
22:37:04 #1 Text 0 File SCSIPTICommands.cpp, Line 411
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
22:37:04 #2 Text 0 File Isodoc.cpp, Line 6608
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
22:37:05 #3 ISO9660GEN -11 File Geniso.cpp, Line 3343
First writeable address = 0 (0x00000000)
22:37:05 #4 Text 0 File Burncd.cpp, Line 3499
Turn on Disc-At-Once, using DVD media
22:37:26 #5 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 33135 ( 7:21.60, 64MB)
22:37:26 #6 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: DVD)
22:37:26 #7 Text 0 File DlgWaitCD.cpp, Line 2949
Recorder: DVDRW IDE1008, Media type: DVD+R
Disc Manufacturer ID: AML, Media Type ID: 002, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 3
22:37:26 #8 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
Insert empty disc to write to.
(Medium in drive: Unknown. Medium required by compilation: DVD R/RW.)
22:37:26 #9 Text 0 File ThreadedTransferInterface.cpp, Line 793
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 33136 (33136) = #33136/7:21.61
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 33136 blocks [E: DVDRW IDE1008]
22:37:26 #10 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [E: DVDRW IDE1008] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 67862528, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 33136 | 0 | 0x00
33136 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
22:37:26 #11 Text 0 File SCSIPTICommands.cpp, Line 209
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
22:37:26 #12 Text 0 File Burncd.cpp, Line 4278
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
22:37:26 #13 Phase 24 File dlgbrnst.cpp, Line 1762
Caching of files started
22:37:26 #14 Text 0 File Burncd.cpp, Line 4397
Cache writing successful.
22:37:26 #15 Phase 25 File dlgbrnst.cpp, Line 1762
Caching of files completed
22:37:26 #16 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 4x (5,540 KB/s)
22:37:27 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
22:37:27 #18 Text 0 File Cdrdrv.cpp, Line 9859
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 3 h
Disc Manufacturer ID: AML.....
Media type ID: 002
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 03 41 4D 4C 00 00 - 00 00 00 30 30 32 00 38 ...AML.....002.8
23 54 37 10 02 4E 72 02 - 8C 63 16 16 0B 0B 0A 0A #T7..Nr..c......
01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................
22:38:44 #19 SPTI -600 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x00) WinError(121) NeroError(-600)
Sense Key: 0x00 (KEY_NO_SENSE)
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x95 00 00 00 00 00 00 00 00 00 00 44
Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00
Buffer x0924d900: Len x4
22:38:44 #20 SPTI -1114 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1114)
Sense Key: 0x06 (KEY_UNIT_ATTENTION)
Sense Code: 0x29
Sense Qual: 0x00
CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x70 00 06 00 00 00 00 0A 00 00 00 00 29
Buffer x09261780: Len x20
22:38:44 #21 SPTI -1033 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1033)
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x04
Sense Qual: 0x01
CDB Data: 0x52 01 00 00 00 FF 00 00 1C 00 00 00
Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 04 01
Buffer x09261780: Len x1c
22:38:44 #22 Text 0 File DVDPlusRW.cpp, Line 674
Start write address at LBA 0
DVD high compatibility mode: Yes
22:38:44 #23 CDR -1033 File ThreadedTransferInterface.cpp, Line 1752
Drive not ready
E: DVDRW IDE1008
22:38:44 #24 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1752
Could not perform start of Disc-at-once
22:38:45 #25 SPTI -1033 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x04
Sense Qual: 0x01
CDB Data: 0x55 10 00 00 00 00 00 00 3C 00 00 00
Buffer x09257140: Len x3c
0x00 00 00 00 00 00 00 00 05 32 01 C4 08 00 00 00
0x00 00 00 00 00 00 00 96 00 00 00 00 00 00 00 00
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
22:38:45 #26 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
22:38:45 #27 Phase 38 File dlgbrnst.cpp, Line 1762
Burn process failed at 4x (5,540 KB/s)
22:38:45 #28 Text 0 File SCSIPTICommands.cpp, Line 254
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
22:38:46 #29 Text 0 File Cdrdrv.cpp, Line 11214
DriveLocker: UnLockVolume completed
22:38:46 #30 Text 0 File SCSIPTICommands.cpp, Line 411
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
