Hi Woodbeck,
A 2.8hdi is a 2.8jtd with a different name. It is a common rail engine, which means that it has an ECU, which will require a diagnostic port. However early HDi/JTD engined vehicles were fitted with a 3 pole OBD connector (2 wires connected) in the engine, close to the air filter and ECU.
The following is copied from a much earlier post by
@BGD.
"The diagnostic plug socket on our 2001 2.8 JTD Ducato (as you stand looking into the bonnet, ie looking rearwards) is on the right side of the engine bay, near the air filter (the big black cylindrical thing at the back right of the engine bay).
It is NOT a three pin plug with THREE wires coming from it (if you have one there...that is for the ABS system if fitted), but it is the three pin plug nearby with only TWO wires coming from it.
Its centre wire is black, its left hand wire is white & red, and nothing comes from the right hand pin.**
Most garages need to use an adaptor to get your Ducato diagnostic plug fitted to their diagnostic kit, and many garages/breakdown people don't have the right adaptor, or don't know how to hook it up, which is why I always carry one in the MH, together with the written instructions below on how to use it.**
Connection of adaptor lead:-
Tape off the end of the Black connector of the multi-purpose adaptor cable, so it can't touch anything metal under the bonnet.
Connect the Red wire of the multi-purpose adaptor to positive (red) terminal of vehicle battery.
Connect the Green lead of multi-purpose adaptor to the left hand pin of the ECU connector (the White and Red wire).
Connect nothing to the ECU connector centre Black wire.
DO NOT at this point connect the black earth wire of the multi purpose adaptor to the negative terminal on the battery, nor let it touch anything metal in the vehicle.
Now try the system. If it works, then DO NOT connect that black earth wire to anything.
ONLY if the diagnostics computer doesn't work , then also undo the tape on end of the Black wire of the multi-purpose lead, and connect it to the negative (black) terminal of vehicle battery, and try the diagnostics system again."
