Technical Need schematics of a gearbox...
Fiat-Iceland
I need some schematics of '92 Fiat Uno Turbo I.E. 5 speed gearbox. How to take it apart and put it back togheter.
Thanks.
Gudni
thepottleflump
Shut Up, Fool!
Surrey
Haynes Manual? I was reading the haynes manual for the Uno while on holiday (sad I know) and it basically said don't do it unless you really have too.
jjhepburn
Hamilton
Newer Haynes manuals are useless if you want to work on a gearbox, they basically say DONT!!! Which is far from helpful when you want to.
The Haynes Fiat 127 or 128 manuals have a good section on the gearbox in them. Although it is slightly different you still get the general idea. Of course the 1.4turbo has a whole new breed of gearbox so it might be completely different (I'm not sure).
I used the 127 manual when I rebuilt the box on my 1108 FIRE, was pretty accurate, it didnt show fifth gear but I worked that out OK. I just went to the local library, found the manual and photocopied the appropriate pages.
Once again I'm not sure about the turbo because its got the newer gearbox and I don’t know how different it is from the older one.
One final note, I think syncros are a bit expensive so it might be worthwhile just putting up with it or buying a working second-hand box. I did the dodgy and used the syncro from my old 4-speed box :eek:
OP
OP
F
Fiat-Iceland
I just bought syncros and I'am ready to rebuild my gearbox, there's no way on earth that I can find an other gearbox here in Iceland.
I'am having trouble getting it apart, I have loosened up all the bolts but it’s still stuck together. Any guys out there with experience or send me a copy from a good book/manual?
[email protected]
Thanks,
Gudni
