General Need quick help
shan
so , like an idiot, i decided to change the spark leads and didnt even pay attention to the order..haha
i randomly plugged everything back in and the inevitible happens...it wont start...
i read the forums...and this is what i come up with....
pictures are attached...
is this right?
The Sultan
Bravo 1.8 HLX FTW
lake windermere east edge
that is correct the rear coil cylinders 1 and 4 no mater witch way round on the coil they are and the front coil 2 and 3
why are you changing them were the originals faulty
and did you change them for fiat parts
I find fiat coils tend to eat crap after market silicone leads for breakfast they might say 10 more hp on the box but silicone leads are crap really
I would put the originals back on and see if it runs if not then you have disturbed something else
if the original leads are not faulty I would use them until they are
don't fix if it ain't broke
ps you should remove the coil cover completely from the car and chuck it in the bin as fiat issued a service news about that along time ago as they were causing coils to overheat it should not be there I have removed loads from old 55s and 60s
if your replacing leads because of a misfire this may also be the cause a failed coil
oktopod
Beograd
All I know is (from manual) that the firing order is 1-3-4-2
So MAYBE the right way would be
1 2 3 4 1
3
4
2
:bang:
OP
OP
S
shan
yeh..it ws missing in lower revs, a mechanic told me i shud get leads and plugs.....they r indeed silicon leads...hmmmm
and now i have got eveything in order...it wont start.....
I m pissed!!!
The Sultan
Bravo 1.8 HLX FTW
they are very easy to flood so try turning it over for at least 10 seconds before you give up
did you mean the leads on the car were silicone s h i t e
or the leads you bought to replace them
ether way I would get original fiat ones there the right length and good for 100k normally
also what plugs did you get they may have the wrong gap or might have been dropped before you put them in
the gap should be 35k and I think ngk bpr6es is correct but don't quote me on that
how did the misfiring begin was it sudden or did it build up over time
because if it was sudden it's more likely a failed coil because of the cover you have on still
sps
guess what when i first bought my car car last year,i noticed that the coil cover was missing,so i went to the scrapyard ang bought one for a few quid as i thought excess engine heat/dust was detrimental to the coils-so i gues i will need to remove the coil cover and chuck it away!.
The Sultan
Bravo 1.8 HLX FTW
yep
