ChromaticBattle
- Joined
- Apr 13, 2018
- Messages
- 4
- Points
- 2
I have a 1977 Fiat x1/9 with a major oil leak. It is a 1.3l i4 soch Carb. From what I can tell it is from a head bolt and possibly the head gasket on the intake side of the engine. The oil sprays up on the hood and all over the air filter as well as anything else in the vicinity. It leaks nearly all the oil put into it within a half hour of running. The engine itself is extremely loud and that is not from the exhaust so I am wondering if I have failing gaskets or if the bolts are tightened to the proper specs or if it’s a cylinder head/engine block problem. Any guidence on this would be much appreciated.
