My Sei ICE setup - Help
Wrexham
I've decided to overhaul my ICE cause i fancy a change. I just ordered:
Infinity 652.5I comps
Infinity 6500CS
Jbl GTO6000
To add to my collection of a GT3 10" Sub, Alpine MonoBloc Amp and Kenwood crappy front comps
Will it sound good and has anyone got any ideas of a suitable install design for the boot cause i'm after as many ideas as poss cause of lack of space. I need access to the spare wheel, so that is a problem.
Also sound proofing, what can I use, will roofing felt be an adequete alternative to dynamat or brown bread. Or is it best to stick with the proper stuff.
Gaz
Seicento Sporting, Modified Front Bumper, Saxo Custom Spoiler, Abarth Side Skirts, Bad Boy Bonnet, Afterburner Rear Lenses, 4" Powerflow Exhaust System, Abarth 14" Alloys.
IN THE PIPELINE:
-40mm Drop
Check out my site: http://badboygaz.mysite.freeserve.com​
Wheres the comps goin?
If your wanting a sound quality install I would just look at amping front comps and amping a sub, thats it. Just keep it simple. Dont bother with rear fill, its not a saloon or anything.
Sound deadening is best used, flashing tape is an alternative but no where near as good, I've used proper sound proofing throughout and the flashing tape on the reverse of panels to reduce creaking and rattling.
Matt
______________________________________________________
http://www.zen8627.zen.co.uk/Matt/
While most Cinqs are unreliable...mines just taking the pi55
ice in the sei boot is never easy, especially if you need access to the spare. i'd make up a board for the base, and attach everything to it, then if you put the back seat down you can manouver the board backwards allowing access to the spare.
alternatively you could do some funky work and attach the entire setup to the bck of the back seats, so that it moves with the seats when you put them down, would look mental with the back seats down from the front too ;)
- - Donz - -
cheers guys, I have a funky idea planned, but need to figure out how im doing it first:I
The comps will be going in the doors, im gonna make myself something to make the comps fit up front.
IN THE PIPELINE:
-40mm Drop
Flashing Tape? Where can I buy this from, and how much?
Thanks...
<font face="Verdana">--
<font color="maroon">'98 Marea Weekend ELX (1.8 16v).</font id="maroon">
- Kenwood MP3 head unit
- De-Restricted standard air box
- NGK VX Platinum spark plugs (BKR7EVX)
- Toyo Proxes T1-S (205/45) tyres on Stilo 7-twin-spoke 16" alloys
- Quad LED blue sidelights
- Type-VR Aluminum Red tax disc holder
- Richbrook Aluminium Red Uni-Hex gear knob with FIAT logo and silver/grey gaiter
</font id="Verdana">
you gotta watch with the doors on a sei, not the most room inside them! just remember and stay clear of the windies!
- - Donz - -
oh ****, i aint seen it yet, thats p1ssed on my chips, i got a spare alpine V12, will that be any good
IN THE PIPELINE:
-40mm Drop
ts86net - flashing tape from any DIY store, it looks a bit like gaffa tape, its used on roofs, if you ask in a shop, they are bound too know
IN THE PIPELINE:
-40mm Drop
Pass. Best thing to do is get all your stuff and see where you can cram it. MDF can create a couple of shelves for more space but will also add a lot of weight to your car!
well it will balance it out with the front:D, ive got a few tricks up my sleeve, will see. Thanks for the help peeps
IN THE PIPELINE:
-40mm Drop
http://international.jbl.com/car/product.asp?prod=GTO+6000%2F230&ser=GTO&cat=AMP&type=&language=ENGLISH
Class : AB
Max Power : 1100W
RMS Power @ 4Ohms : 4X50W + 2x75W
RMS Power @ 2Ohms : 4X75W + 2x125W
RMS Bridged : 2x150W + 250W
Freq. Response : 10Hz - 40kHz
THD : 0.1%
S/N Ratio : >92
Bass Boost : +6dB @ 45Hz
Crossover : Ch 1/2, 3/4: Flat/HP; Ch 5/6: Flat/LP
Variable : 30Hz - 320Hz
Slope : 12 dB/oct.
Input sensitivity : 250mV - 4V
Dimensions (WxHxL) : 568 x 55 x 294 mm
