General My punto
General My punto
JjPhoenix said:
ive got cd playe nw n i want 12" sub £200 roundabout but im getting stuf cheaper cause my friends bro...
£200 for a 12" and a suitable amp? OK...............I'm going to use a budget of £150 to allow for wiring and installation :) Biased to £50 for a sub with £100 for an amp..................
£50 subs
http://www.caraudiodirect.co.uk/pro...d=4035&cadid=1f1e13160857da6d159972915e08ce10 150WRMS, £35
http://www.caraudiodirect.co.uk/pro...d=3031&cadid=1f1e13160857da6d159972915e08ce10 400WRMS, £40
http://www.caraudiodirect.co.uk/pro...d=4048&cadid=1f1e13160857da6d159972915e08ce10 400WRMS, £44
http://www.caraudiodirect.co.uk/pro...d=4218&cadid=1f1e13160857da6d159972915e08ce10 300WRMS, £45
http://www.caraudiodirect.co.uk/pro...d=4579&cadid=1f1e13160857da6d159972915e08ce10 4ohm DVC (therefore need a 2 ohm amp), 250WRMS, £48
This is just a small number. You basically want an amp that does about 400WRMS in mono mode
£100 amps
Mono
http://www.caraudiodirect.co.uk/pro...d=4133&cadid=1f1e13160857da6d159972915e08ce10 204WRMS @ 4 ohm, 294 @ 2 ohm, £100
http://www.caraudiodirect.co.uk/pro...d=4626&cadid=1f1e13160857da6d159972915e08ce10 300WRMS @ 4 ohm, 450WRMS @ 2 ohm, £100
2 Channel
http://www.caraudiodirect.co.uk/pro...d=4139&cadid=1f1e13160857da6d159972915e08ce10 290WRMS @ 4 ohm, £80.
I don't know how much discount you'd get from your mates, so I had to assume that you weren't getting 'mate's rates', but paying full price :). This is just to get you started (y) Hope it helps :D
JjPhoenix said:
yeah, everyone does lmao, I dunno why but there seems to be some kind of attraction. I always thought the bassist was the cool one in the band...
Back to topic, £50 is probably a good figure, as a general Cable set (Power, Remote, Earth and Phono) will cost around £20-25, A piece of Plywood about £10 and Various Fittings/bolts/screws cost around £5
add into that some beer and some chocolate and you're about there...
U can listen to my system, which is a single 12" woofer, the FLI, which costs ~£150 at the moment, but u can probably get it down a bit by shopping around for example here - http://cgi.ebay.co.uk/VIBE-FLI-12-ACTIVE-BASS-TUBE_W0QQitemZ5856593783QQcategoryZ18805QQrdZ1QQcmdZViewItem
and that's for pickup from Billingshurst...
legend :worship: :D
cinqysxmk2 said:
well, it was a case of french vs. a break from french
I used to enjoy French..............I dunno if the male:female ratio had anything to do with it :chin: ;)
