phatbenny
My Panda keeps on trying to stall, always as I change gear to second, either up to or down to. I'm convinced it's a fuel supply problem. Recently I lost the pushrod from my fuel pump so replaced it with one from a pumpfrom a scrappy. The pump looks slightly different, so not sure if the pushrod will be a different length either. Might be. That may be the problem, but i think it might have something to do with the carburettor, but I don't know what. I just cleaned my carb with a spray, just before I had the car tuned. Also, don't know if this is related but my panda won't start with the choke out. You have to start it with it in, then pull it out slowly once the engine is going.
Any thoughts?
Ben
Any thoughts?
Ben
