Cinquecento My cinq feels too high
Well i decided my cinq was feeling a bit high so thought i would make use of the big barge of a range rover outside to make myself feel a bit better :slayer: :D
Hellcat
zombie nation
on the A684
Someone has pinched the numbers off your number plates! You can't leave anything these days.
arc
this is where i stand
Manchester
GhostWKD said:
bet it was you while i was getting my hands dirty fixing your cinq :rolleyes: :p
nah, i was busy trying to sus out how to fix yours :p :D
arc
Manchester
GhostWKD said:
but this isnt my cinq being worked on at an unholy hour ;) :nerner:
Helz said:
Did you get home OK Arc? Was chatting to Alex when you phoned him and returned :(
i did indeed. got back around an hour or so ago. Rear engine mount had come to bits and was trailing on the ground when i took my foot off the accelerator. Not a good thing to have happening.
arseofbox
Principality Retained :)
Midlands
Is that buggery an unholy hour!!
1am is an unholy hour...I did that when I was doing the 1242 swap :)
OP
OP
GhostWKD
GhostWKD
Winning
Banbury, Oxfordshire
lol unholy hour when i was hungry :( we gave up after couldnt find a nut to go with the bolt i found that just happened to fit :p and jumped in turbo cinq to go chinese :yum:
Carlisle, UK.
Thank goodness! Did you get it back into place with no ill effects?
arc
Manchester
well as alex said above, we couldnt find the right nut and bolt for it - so we called it a night, and got chinese and vodka instead (y)
It was making an odd nosie on the way back to stafford when i lifted off the accelerator, that was cured by not lifting off very often :D
Chii will be getting some attention on wednesday i think, then MOT is soon :eek:
