I'm still in two minds about a carpooter, it might fit in there nicely or just a Handy place to leave valuables while out of the car.
I removed the bowl bit that was there then refitted the airvent, glovebox and centre stereo/airvent panel. I was thinking I would peel the material back from the two edges of the airbag cover and cut a few mm of metal off each edge before sticking the material back down, then fabricating some sort of hinge and catch.
It needs trimming down a little so it clears the airvent and centre panel, but it fits nicely at the moment, just by slotting it under the airvent first then pushing down the other end. There was some tags around the edges that were used to bolt it in, I just bent them backwards and forwards untill they snapped off.
I'm not sure if its upset the balance of black and grey on the dash though, I swapped to a black airvent, glovebox, ashtray and it looked good, not sure if the black airbag is too much or if it will look ok once I get used to it.
TDF.
