had it run up to temperature today, timing needs some attention. i wonder if the TDC marking is still in place on the flywheel. i need MS setup properly before i even start faffing about with it.
kristian, what did you use to bloke off the ICV? On the 8v i could get anway with a bit of gasket and wedge it between the two parts of the TB, on the 16v tb tho this is not possible.
