ELM327 is kind of a passive device; the 12v input voltage is internally regulated to 5v to feed the µchips and other components so IN THEORY it shouldn't send more than 5v to the CAN pins which (both A-B and L-H channels) are the only ones connected (beside power) on GPs.
MES requires only the yellow adapter or direct connection, maybe by trying other color adapters you unluckyly sent 12 volts where it shouldn't :-(
BRs, Bernie.
You’ve kind of reassured me Bernie ?, I did measure 4.xx volts on one of the pins can’t remember which one though,
I’ve also noticed after taking a closer look at the obd port, it looks like the female pins are spaced to far apart, now this is making me wonder if that’s the problem,
I’ve ordered another diagnostic lead from a guy On eBay who said he Modifies them hisself and knows it will definitely work, Just to rule out leads
What I’m going to do with the cheap WiFi reader is take it apart and connect it back up to the obd port then Check for continuity, I’ll probe the Wifi internals and Then back probing the obd port to make sure each pin in the socket is getting a connection,
