HI every one i have problem with fuel pump in my ugly bug.Fuel pump stoped working,already replaced but no working anyway.Where is fuel pump relay/fuse on multipla JTD 2000 110bhp?Please help:bang:
Please note that the original document contains errors – there are references to a fuse 28 and 29 which do not seem to appear in the diagrams in the book, while no components are assigned to fuses 30-32. I recommend that you check the rating of the fuses that you are taking out; during transcription I discovered that fuse C1 (fig.37 fuse 1 in the book) is listed as being both 7.5 and 15 amps.
Oddments tray fuses (check amperage!)
1 (10)
2 (10)
3 (20)
4 (10)
5 (30)
6 (10)
7 (10)
8 (10)
9 (15)
10 (20)
11 (20)
12 (10)
13 (15)
14 (10)
15 (30)
30
16 (7.5)
17 (7.5)
18 (20)
19 (25)
31
21 (25)
22 (7.5)
23 (7.5)
32
25 (25)
27 (20)
Found this online and that solved a fuel pump issue on a 2005 multipla try that it has a diagram of interior fuse box didn't realise I could edit hope this helps
Personally from past experience it on old mk1 is fuse (a5) under the bonnet and there is a fuse for fuel filter on there as well it is a cube fuse and will be able to get one from motor factors // fiat // scrap motor not many places stock them
