- Joined
- Sep 29, 2013
- Messages
- 446
- Points
- 172
PLEASE NOTE! the only way I found to put the full message of this post on here is as a zip file- there must be a better way, but not aware of it; the text is here readable, but the screenshots referred to are in the .zip along with the text, I can only save it as a Rich Text Document or .doc, which loses the pix. Anyone knows how to put screen shots on, pls point me to where I can find out how. DOH! Cheers.
Ok folks,, in case this helps, I have put some screen grabs here in case anyone can spot anything untoward that needs to be changed. This all relates to the kkl lead of course, as plugged in to laptop, but NOT yet connected to the vehicle.
One issue I get, is the in the 'port settings' tab of the com 11 usb/serial, is the speed keeps resetting to 9600 (which IMHO is fast enough?), does it need to be 115000, and do I need flow control on or off? Default is 'off' and not tried anything else.
In the 4th screen shot, what is 'load vcp', and should it be ticked (is it load Virtual Com port)? This should cover all the hardware variables, there is a rs232 serial on the machine used for the screen shots, but not on the laptop used in the vehicle, so can't adjust fifo buffers on that, but I can on the one used here which is my desktop PC at home.
Can a kkl lead be used with a usb lead extender, I have an active one. My worry is complicating things! Cheers to all our readers!!
