HI, I have problem with airbag light doesn't turn off, and have bought Cable Unit with 3 pin adapter for Multiecuscan 4.9 version, and having following condition.
- Setting up softwares on my Windows 10 PC was successfully done with the help of engineer from where I bought the cable unit.
- I confirmed that there are 3 airbag connectors with 3 pin for the cable unit. One under the steering, one at the left side of driver's seat, one under dashboard at passenger airbag location.
- I confirmed that under dashboard connector is not right condition because when I connect cable unit with it, a lamp on the unit doesn't turn on. I could confirm that when I connect Driver's seat side 3 pin connector, the light on the cable unit turns on.
- Even though connecting the right condition 3 pin connector at Driver's seat side didn't react to the Multiecuscan application in my PC.
What do I have to do in this situation?
Does the Airbag computer under the dashboard is not operating, and that's why Multiecuscan doesn't react? Should I do something about the battery connection(turn off and turn on) before I do the same procedure?
Maybe I should try working with 3 pin connector in Engine room for Engine should be tested, and see the result.
If you have any similar experience, please help for me. My Barchetta is 1998 model, and everything is fine except for the airbag light.
Thank you.
Thank you.
