Hey people...
I know technically I may be in the wrong section to ask, however I know from being on this forum for years this is normally the best section for advise, and a lot of you run, or have experience of megasquirt!!
Im basically looking to run spark & fuel on a mk2 uno turbo engine, however a little confused as the original engine is a dizzy set up and I cant seem to find anywhere that shows how to drive the spark by the MS system only. The closest thing I can find is the image attached, and that looks to only control a single coil, which then I guess feeds the dizzy and then to the plugs?
Ideally I was looking to bin off all the standard ignition side of things, having the ignition directly driven by MS (using drivers), and then installing the MAP & air temp side of things on the fuelling (trying to use all the normal sensors, but binning off the standard UT ecus)...
Any help would be grand...
